mep-802a gen fuel injector leaking
Ray70
5,426
West greenwich/RI
Take out the injector and clean the copper washer between the head and injector as well as the head and end of the injector body.
You can clean everything, hit the copper washer with a propane torch to anneal it and reinstall.
You can tighten down the clamp then tap down on it with a hammer and a blunt chisel or long bolt etc, then tighten again.
That should stop the leak.
