cuad4u
- 89
- 28
- St Matthews, SC
Even though I have refurbished some 30 MEP 002A and 003A generators, I know very little about the 802A and 803A.
Recently (4 months ago) I bought a reset 802A with 4 hours showing. The paperwork indicates that a brand new engine was installed. Frankly the entire unit looks to be brand new.
When I got it home it started right up and ran perfectly. All I have done is crank it and exercise it once or twice a month and do a couple of load tests, all of which indicated the unit will easily pull 125% of rated load. The hour meter now reads 11 hours. I have run it 7 hours since I bought it.
Today when I started it up it ran about 2-3 minutes and shut down. The NO FUEL fault light came on. I reset the fault light and it cranked right up and ran another 2-3 minutes and shut down. This process repeated itself about 5-6 times before I gave up.
The fuel tank is FULL to the brim. All filters are new from the reset. There are no fuel leaks. All wires and connectors look to be OK. There is no mouse or rat damage.
The unit ran perfectly and as long as I wanted to run it for the first 7 hours I ran it. The fuel pump clicks and runs but it does not slow down after the fuel system is primed like the 002A and 003A. Is that a clue? Any info would be greatly appreciated as to where to start. I have downloaded the manual and have been looking for some clues, but I thought I would ask here as well.
Thanks
Thanks
