- 2,333
- 4,205
- 113
- Massachusetts
My 802A has developed an intermittent starting problem. It has me baffled.
I've had it for about 4 years and has always promptly started. It gets used almost weekly to test products I build for the 802/803 such as the Remote Start and an "new" product.
Today I was using the 802 to test products. Started and stopped it numerous times this afternoon.
Shut it down to switch products being tested.
When to start it and the engine cranks just fine at normal cranking speed but will not fire and no puffs of smoke.
I checked...
Fuel tank is full
Fuel Shutoff solenoid is fully retracting and lever on governor rotates full from stop position to run when cranking.
Removed the fuel tank cover and disconnected the fuel return.
Set S1 to Pime/Run and got a healthy stream of diesel. Had pressure and sprayed as I put a finger over the return line.
Hook return line back up.
I let the system prime for a good minute. Cranked it again and no start.
Let it sit for 10 minutes.
Came back and it started just fine.
Let it run for about 10 minutes as I put the fuel tank cover back on.
Shut the set off.
Tried to start it again 3 minutes later and back to cranking but not starting.
Waited 10 minutes, tried again, cranks but will not start or fire.
A few weeks back while testing products it did the crank and no just start once amongst numerous of normal starts and stops.
Cranked it again and it start and ran fine and continued my testing and did more normal starts & stops.
Thoughts?
I checked...
Fuel tank is full
Shut the set off.
Thoughts?
