Max Bladwin
- 3
- 8
- Michigan
Hello,
For some backstory I lived in the city and was only able to run my generator a few times, I had to replace the temperature gauge because it was a little sticky it needed a technical tap to get the needle to jump. However the temperature needle always hovered just above 190. I moved out of the city and now I have all the time to run my generator as much as I like so, I replaced it and this new gauge holds a temp around 220. My question is what should I do? Is this a normal temperature do I have a stuck thermostat or possibly is the current gauge I got a little off? Is there any way to test the gauge? Thank you.
