MEP 803 Fuel filter on Aux. input
CapePrep
197
MA
Hi Guys, I am putting my aux. fuel hose/tank pipe together. What are your thoughts on installing a filter on that set up so fuel is filtered before it hits the pump? I am using 1/2"copper fittings before the aux. hose. Let me know thoughts.
Daybreak
2 Star Admiral
1,522
775
Va
Howdy,
The small barrel filter. NSN 2910-01-553-6571 FILTER ELEMENT,FLUID (small barrel filter only) PART# 00-24000
It is attached to the fuel pump.
Also known as Airtex G-17. fuel filter - 300 micron
Filtering diesel is always a good practice.
Light in the Dark
6,761
MA
Is it easier for you to filter the fuel before it hits the machine, or in the machine? I would think you will get a higher flow rate (and possible better filtering) if you go with an inline filter before it even hits the machine.
CapePrep
197
MA
I guess I was wondering (guyfang??:)if that little pump, that is actually sucking fuel for quite a distance vs. pushing it, is capable of handling a filter on the intake side? I have always been told it is better for a pump to push fuel as opposed to pulling it, especially where we have the long aux. hose and other fittings, etc. Since I had a situation a few weeks ago where I needed to run the 803 for 24 hours due to a power outage and had to keep checking fuel level, I want to use this machine as it was designed. But also want to protect it and it's systems. Hence the filter since I will be connecting it to an aux source next time so I don't have to worry about it.
csheath
216
FL
This is a good idea I will employ on mine. I have small engine filters on the supply line on both my tractors. Those little $3 filters are much easier and cheaper to replace than the larger OEM filters.
I didn't know what micron ability those little installed filters had. I do know I have sucked some crud up that would pass through on a similar pump I use to transfer fluids with.. I think it's just there to keep the pebbles out. :)
Farmitall
280
Eubank, KY
A filter right out of your source is a good addition as long as you can maintain hydraulic continuity in the system.
