MEP-803 locking up, help?
Chainbreaker
2,112
Oregon
A non-rotating core sounds like water intrusion flooded engines that were missing the exhaust flap. Rusted cylinders and stuck rings come to mind. Though many have been resurrected with a cylinder hone & rings. Of course there could be more catastrophic failures but you gotta roll the dice to find out.
Regardless, if you can hand pick you just might get lucky & get off lite as far as repairs to bring it back to life.
INFChief
1,349
New York
I really think the motor that I’m replacing has all the parts I need aside from a good block, head and 1 piston. So I can use it as long as the core motor is stock bore. The guy has about 8 motors at that price, and I can hand pick which I want. As is I have $800 in the purchase of my generator and $300 in batteries.
Have you checked to see what your options will cost in comparison? For example;
Resleeve / new cylinder liner (and bore & hone & run bigger pistons if the undamaged other bore is too worn).
If the crank needs turned down or replaced?
Full gasket set, new rod & crank bearings, oil pump, etc.
I have no idea what a new or reconditioned engine costs but comparing that to repairing your block versus buying 3 or 5 per unknown blocks hoping one has a good block.
Again, I’m not familiar with those particular engines but getting a SBC or BBC resleeved and bored honed to size is not too expensive.
