Mep-803 question
chilbun28
Deep South
Hi, I just bought another 803 to have as a backup. This one has "IP" painted on it. Does anyone know why they paint letters on them and what it would mean by any chance?
Also, the diesel fuel hose coming off the fuel rail has a leak. Is that 1/4" hose? And should I dremel off the outer metal cap so I can get a hose clamp to tighten it dow properly?
Jeepadict
617
Round Mountain, NV
That fuel line is crimped on. If you're delicate about things, you can remove it and use reg hose and a clamp unless you really want a new assembly. You should read the other posts about replacing the return lines too.
Sent from my SM-G970U using Tapatalk
rickf
1,510
Pemberton, N.J.
The IP is probably 1P and is just an inventory marker for the people at DRMO, Richie Bros., or the unit disposing of it.
Light in the Dark
5,648
MA
Yes to 1/4" primary hose, yes to dremeling off and replacing with a hose clamp. Yes to doing the returns at the same time. Spray paint probably has no obvious meaning tied to the machine.
