Mep 803 with problems shutting down
Triton
82
Houston, Texas
Well I looked at the relay when starting the unit, the crank disconnect and flash relay activate. When I disconnect the fuel solenoid to shut the unit off the crank disconnect open when the motor comes to a full stop. That was the only relay I could see operating. I also checked the 137n wire disconnected with the unit running, it has 24volts on the wire so something is back feeding it. I'll trying to read the schematic to see where 137n goes.
DieselAddict
2,345
Efland, NC
Can you please read the voltage at pin "N" in the diagnostic port with the engine running and S1 in the "OFF" position?
Can you please read the voltage at pin "K" in the diagnostic port with the engine running and S1 in the "OFF" position?
Measure from pins to ground.
Triton
82
Houston, Texas
Pin N reads 0 volts engine running and S1 in the "OFF" position
Pin K reads 24volts engine running and S1 in the "OFF" position
Used pin B as ground
DieselAddict
2,345
Efland, NC
Ok. Great. We have eliminated the starter solenoid as the problem.
If you have 24v at K with the switch off we need to track that down. Both should be 0.
DieselAddict
2,345
Efland, NC
Please read the voltage at pin "R" in the diagnostic port with the engine running and S1 in the "OFF" position?
DieselAddict
2,345
Efland, NC
If you have some alligator clip wire jumpers I would recommend that you shut the engine down and remove the wires from terminal 3 on S1. Put the wires together on one end of the clip and clip the other end to terminal 3 on S1. Tape up that end so it stays together and doesn't short against anything.
Start the unit then move S1 to off. Remove the clip from terminal 3 of S1. Does the engine stop?
Triton
82
Houston, Texas
Ok I just tried that and it did not shut down, it's kind of strange that without the wire connected to the starter solenoid the fuel solenoid shuts off fine.
DieselAddict
2,345
Efland, NC
Another question, all the gauges continue to read correct values when S1 is off and the engine is running?
Triton
82
Houston, Texas
All gauges are working except the voltage gauge (that works intermittent) the battery gauge works and charges and there are no fault lights
DieselAddict
2,345
Efland, NC
You're welcome. We will get this figured out.
I also think we need to revisit the first set of reading now that you have the correct pin-out of the diagnostic port. I still think the problem is with the starter solenoid.
