- 4,523
- 2,624
- 113
- East of Edmond, Oklahoma
I took radiator cap off this evening and think i found out why it wasn't sealing.
There is a decent amount of hard water deposits, a layer, that was on the neck rim, inside the neck and on the cap itself.
I soaked the cap in vinegar and that solved that issue.
Took a brass brush and removed the scale on the neck rim.
Should seal now.
Flushed radiator and it was rather nasty.
I added one gallon of 30% vinegar to the radiator and filled the rest with regular water.
I know I should be using distilled water and will do so once it's drained and ready for refill.
I did not start the engine and let the vinegar run through the water pump and engine.
Didn't know if it would cause any issues.
Fuel Filters changed.
AUX fuel pump installed. Verified that it works.
Tank Cover reinstalled. That was no fun.
All stainless hardware used.
Replacement oil fill cap installed. Old one has a chunk of the underside missing.
Should seal now.
