MEP 803A & 802A trailer mounting rails
Light in the Dark
5,510
MA
[h=2]5975-01-454-2767 Features[/h]
MRCParameterCharacteristics
ABHPOverall Length66.500 inches nominal
ABMKOverall Width6.000 inches nominal
AGAVEnd Item Identification10KW generators nsns 6115-01-275-5061-60H, 6115012747392-400H
FEATSpecial FeaturesRefer to dwg for dia, sz, lg, Qty of mounting holes, and dim
MATTMaterialSteel
So here are your basic overall dimensions. All you really need to source is rectangle tube stock, of whatever material is your preference (then add mounting holes for the rail to the trailer, then for the genset to the rails). If you have a raw metal supplier near you, make some calls. Buying it from an online seller will break the bank.
Zed254
466
S. Hampton Roads, VA
I had a project where I wanted to match the 2-1/2" hat channels on a generator trailer. Could not find hat channels anywhere but I did find some 2-1/2" square x 1/4" thick aluminum tube in .... Salt Lake City......http://metalremnants.com/ . Was not particularly cheap, but they had something that worked for me. If you don't have an existing trailer Lowes, Harbor Freight type stores may have something that will work. If you just want to move it around your garage floor I've seen a SS member's idea of putting casters on boards that fit inside the fork lift channels - search the site for it.
Demoh
26
St Pete, FL
Are you going for a smaller footprint than what you have or do you need an actual trailer for them? I actually have one of my trailers that I took a gen off of up in panama city (minus fenders also) and I might have a spare set of rails. when I am working in the shop tonight or tomorrow Ill see what I have left from the trailers I have cannibalized. Might actually have another full one with fenders but dont recall right now.
Light in the Dark
5,510
MA
If you are still in the market, exactly what you want is on the big auction site right now. Use the search term '[FONT=&quot]generator mounting rails mep-802a mep-803a'[/FONT]
Light in the Dark
5,510
MA
Yes they do. The aluminum rails are quite strong, far stronger than what the application calls for.
