Sodamo
- 0
- 6
- Ninole, Hi
.... But it's a box mounted on the right side of the fuel tank compartment, as you look inside. Next step should be the relay. Look at the schematics. Some of you guys give me a hand here. This blows, not having my TM's.
Had a productive day.
With some last minute telephone support from Peter at INOVA, I was able to finish install of my INOVA auto start panel. Peter had to assist me with the last connection from K8 with actually completes the power circuit and verify I wired in the relay from my Outback correctly. Once installed and tested I ran the wires from the Outback system. I installed this as a backup to my primary generator but am thinking I want to run regularly in rotation with my primary.
Here is the panel installed, my relay above it.
Here it is running
Here is is my manual transfer switch indicating it is the generator being controlled, is the generator producing power, and that power is going to my Outback system.
Shot of of my Mate 3 showing how much power being generated 7.9kw
Soooo, what does this mod do for me?
1. I can still run the MEP standalone.
2. My Outback can auto start/stop the generator according to preset parameters such as low voltage, state of battery charge, exercise schedule, or a must run schedule. And I can monitor, affect these parameters remotely on the web.
3. I can start/stop generator from the Outback control panel. Limited use unless combined with #4.
4. I can start/stop generator remotely from my iPhone, iPad, computer.
W
Would like to find more robust switches that connect the Outback, maybe even a single on-off-on. My original thought was that the switch and breaker be tied to stay in sync. Of course, ideally, I could switch those functions remotely, but likely beyond my expertise
So so now I have some tidying up. The next phase is to tie in the aux fuel line to my 125gal tank.
I had that concern myself, but Peter got me straight. The board does take care of it and unloading for shutdown. As Peter told me there are various wiring configurations, the instructions don't show them all.Got a question, with your auto start system. How are you activating the ac interrupter to send current to the lugs? Does the Inova board do this or do you have to do a modification to send current to the lugs?
