- 4,039
- 6,761
- 113
- MA
No ingress there... just for air ducting. Bastard would need to have drill bits for teeth to get into the machine from there.
Not needed there. They can't get thru there.radator also?
Can more mufflers be added to exhaust?Not needed there. They can't get thru there.
Yes!!!Have you noticed. Great minds think alike!
No, just curious . my gen is under a roof need to run it up should I use larger dia pipe?They are not designed for any additional backpressure which would come from such an addition... I would not do it. These are very quiet sets... not hospital grade quiet, but damn quiet to me. Do you find yours is loud??
No thank youIf you want loud. Stand next to a 150 KW turbine gen set.
Thats your call... set was designed for the pipe size as is. Larger shouldnt be a penalty (typically isnt on diesel systems as they do not want backpressure). I would just make sure you do not have needless angles or bends in the exit pipe.No, just curious . my gen is under a roof need to run it up should I use larger dia pipe?
ust meThats your call... set was designed for the pipe size as is. Larger shouldnt be a penalty (typically isnt on diesel systems as they do not want backpressure). I would just make sure you do not have needless angles or bends in the exit pipe.
Also if you run additional piping, you will want a flexible section of pipe somewhere in line to basically dissipate any excess NVH (noise, vibration, harshness).
whitch TM has wiring diagrams ?Happens all the time to old folks.
I can' find themWhy are you ordering anything? The TM's are here in the forum for free. You do know that?
Look above, I provided the link to the technical manuals section, related specifically to your machine (MEP-803A).that is just one of many things I can't do
