MEP 803a Fuel Drain?
Zed254
468
S. Hampton Roads, VA
Above posts should get you heading in the right direction.....
Parts you are looking for from ARMY TM 9-6115-642-24P:
32 PAOZZ PAOZZ PAOZZ 93742 69-539-2 .CAP, TUBE 2 2
33 PAOZZ PAOZZ PAOZZ 96906 MS87006-11 .HOOK, CHAIN,S 2 5
34 MOOZZ MOO MOOZZ 30554 88-20071-196 .CHAIN, WELDLESS MAKE 2 2 FROM P/N RR-C-271TY2 CL7-16 (81348), #14 X 4 INCHES
LONG
35 PAOZZ PAOZZ PAOZZ 79470 695 .COCK,SHUTOFF,SCREW 1 1
36 PAOZZ PAOZZ PAOZZ 30554 88-21117 .ADAPTER,STRAIGHT,PI 2 2
37 PAOZZ PAOZZ PAOZZ 30554 88-21166 .WASHER,FLAT 2 2
38 XDOZZ XB XBOZZ 07707 A3816 .NUT 2 2
m-35tom
226
eldersburg maryland
If you are talking about the connection to the plastic fuel tank, that is in fact a wellnut with a washer on the outside for the fitting to push against.
Guyfang
27,237
Burgkunstadt, Germany
Surf,
Did you have any luck finding the correct part for your 803 fuel drain? I am in the same boat, everything I read said I had to order a well nut, but the one I was sent is way to big for the bottom drain. Plus I cant seem to find the petcock either. I need both the well nut/grommet and petcock. Thanks.
One of the members here, Daybreak, has a thread call "the infamous wellnut", or something like that. Look for it, or PM Daybreak. There is something better then a well nut. Read the thread, get the right fix.
