- 3,599
- 5,222
- 113
- MA
Have a low hours 97 803A that was put in storage back in 02. In reading through the documents, they flushed the cooling system with oil as part of their procedure. It calls out that they sealed every opening (and warn to remove cover from air filter as part of getting it operational again), and that I can flush with 180* water and fill appropriately.
Any thoughts as to the best way to fill this? As that's about the operating temperature of the machine... would it make sense to just fill with distilled water and run long enough to get up to temp, and drain? Obviously I can rig up boiling water through a funnel and hope for the best. Just wanted to see how others have tackled.
Also they mark that all openings have been sealed, but should there be anything that I check prior to cranking? Thanks
