MEP-803A injector leak
rcamacho
916
Bainbridge Island Wa
Looks like there is an external diesel leak originating from the injectors. Lines look ok, no leaks. Are there o-rings or other serviceable seals?
Daybreak
2 Star Admiral
1,522
775
Va
Howdy,
Look closer, it's probably the fuel return line. They weep fuel after some heating cycles and age.
rcamacho
916
Looks like the high pressure lines not the return. Degreased and lightly pressure washed. Retightened the high pressure line fittings.
Bmxenbrett
30
NY
They are metal to metal for a seal. Usualy nothing happens but they could be loose or have got dirt between the mateing surfaces.
rcamacho
916
One of the high pressure lines was not fully tightened. I’ll evaluate if the flares are cracked on next startup.
