chilbun28
- 116
- 33
- Deep South
Hi, I just bought a 803A for my parents as mine has proven to be the ticket for my needs. The one i just bought is a 2007 model, just got it home and did a filter and fluid fill, put in hot batteries and absolutely no power at the panel, no response from the fuel pumps, no panel lights, no clicks, nothing. The little circuit breaker behind the panel doesn't appear to be tripped, the fuse looks good, and the emergency stop switch is pulled out. I tried the dead crank switch and the motor turns over so i put the switch back to normal. All wiring behind the panel looks factory with nothing out of place. I assume i need to start testing switches although i haven't ever dove into using a multi-meter much. Is there anything simple i'm overlooking or a good go-to place to start finding where i have power and where I don't?
