MEP-803A No Start
Kempho
Central Ohio
Still new, only half a clue. I bought 2 MEP-803s mounted to a trailer and neither one ran in the inspection report. Both are very low hour units, when they inspectd them the 17 hour unit wouldn't crank (it was out of fuel and fired right up), the 25 hour unit cranked but didn't start. The 25 hour unit tries to start, occasionally fires on one cylinder, sounds like it has good compression by the load on the starter, and has fuel in the return lines of the injectors. The fuel cut of solenoid (not sure if that is the exact term on these) is pretty warm after 10 or so seconds of cranking but it does pull the lever on the injection pump. What are some common things or next steps that I should be checking? I also need a couple of small parts, cap for the coolant overflow jug, alternator charging fuse cap picture attached if anyone can tell me where I can get those please?Fuse cap and Fuse.jpg
