mep 803a power at lugs one time
kloppk
4,136
Pepperell, Massachusetts
When running with S5 in the center position S5-5sshould have 24 volts on it. When you lift S5 S5-5 should go to 0 volts.
Seems that's what you have working now.
With the set running and you lift and HOLD S5 UP does the Contactor lamp illuminate?
Does it stay illuminated when you release it?
Walter J Riedel
Harlingen, Texas
it does not light up. Contactor does not illuminate. it does on push to test. Just tested S5 per TM and it is good.
Walter J Riedel
Harlingen, Texas
It's working. Probably J6 connectivity issue. One other issue. Amp meter shows discharge instead of charge. Alternator checks good. 28 volts. Battery's are charging at 14 volts. Thoughts?
Sent from my BE2028 using Tapatalk
Ray70
7,053
West greenwich/RI
Check the ammeter for reversed wires on the backside. Reversed wires makes it read discharging instead of charging.
Should charge at 10A+ and slowly come down to zero within a few minutes.
