MEP 804 A External Fuel Fitting Size
Florida Marine
North By God Florida
I want to add external fuel...have been all over the manuals, and one...cannot nail down for sure which is the fitting, and two cannot find anything via the NSN's that I am guessing are it.
Has to be a standard AN fuel fitting...
Help?
Light in the Dark
5,146
MA
csheath
196
FL
And good luck finding just the fittings. Seems all the generic suppliers I have looked at jump over -5
Light in the Dark
5,146
MA
Why reinvent the wheel? Just source a milspec aux fuel hose (part numbers called out in the thread I linked to) and if you are going with a drum, transfer tank, or other holding body with 2" bung on it, use the milspec bung adapter. What kind of tank are you intending on hooking to?
pjwest03
35
Vestal/NY
That is what I am finding also... I am going to check at the hydraulic supply folks I use to make hoses for my tractor.
5 AN hard tube nuts are available. 5 AN male to 6 AN male adapters are also available. You could use a short section of hard tubing and a 5-6 adapter. Both Earl's Performance and Aeroquip have these parts.
Florida Marine
Stopped by a hydraulic shop today...got a 10' length of 3/8th hose with a pressed on fitting for 36 bucks...fits like a charm, and I can now modify the open end to do whatever I need...and can modify it when I need to.
