MEP-804A Low Voltage - Voltage Regulator Question
LuckeyD
340
Vilseck, Germany
Hey! You are correct. It was late. 005563350 or 005565306 for the Libby. 10 K Ohms. The Kits 013630493 and 015006070 for the Libby. Mr PEAPVP is correct. Recommend being careful on that cage code. The vendor changed many times over the life of the gen. The last ones were just a carbon board and a wiper so current normally was not an issue I suppose the engineers thought. Last ones I got was at a store in Be' er Sheva Israel while on a mission.
LuckeyD
340
Vilseck, Germany
Oh the one check was ro measure thru the voltage adjust R1. That puppy is a 10K Ohm POT so you should read around 13K OHMs on that one. Hope the rest helps. If the fuse is OK, it is probably the regulator or a wire issue. The checks will show what is what.
RonK
9
Vermont
The fuse is good and the pot / VR measure 13.5K CW 3K CCW
RonK
9
Vermont
I was doing the VR tests in the PDF that LuckeyD posted above and things were not looking swell.
I decided on a hunch to just pull out the VR so I dug into my junk, found some wire number labels and took it out.
I removed the board and this is what I found:
My 40ish years of experience in the electronics industry tells me that this VR has seen better days.
Where do I get a new one?
I found this one: https://greenmountaingenerators.com...1-363-0493-6110-01-384-7192-6110-01-363-0494/
Anyone have any experience with aftermarket VR's?
Thanks for all of the help!
Ron
