TacMac2012
- 142
- 43
- Wallburg, NC
I have a new to me 804a, when I got it home I put batteries in it and started it up, ran fine. I got it hooked up to the house and let it run under load for maybe an hour, no issues. Yesterday I went out to start it and it would crank but wouldn't start. I replaced the fuel filter (the spin-on) and then found the fuel primer pump seemed to be leaking, it also would not prime the system. I took the primer pump off my FLU-419 and installed it on the generator and primed the system, still no start....
That brings me to my current situation:
I ran jumper wires from the shutoff solenoid to the batteries, this allowed the unit to start up, but it was noticeable higher RPM than it should run at so I pulled the wires off the battery to shut it down (it ran like this less than 5 seconds).
I have looked at the wiring schematic but I can't determine what the shutoff solenoid is actually called, because they can't just call it something obvious (like "fuel shutoff solenoid").
I am going to download and look through some manuals (ugh) but was hoping someone had a similar issue they have already worked through.
Thanks
Thanks
