MEP-804b 15kw Generator - Won't Produce any Voltage
roselps
Shepherdsville Ky
As this is an issue with a different unit than the thread was started about, you need to start your own thread.
Every issue with every different unit gets it's own thread unless directly related, that way you get advice specifically for your problem, and nobody gets confused about what info goes to which problem generator.
Other than that, yes, this would be the correct forum for all things generators
Thanks for the info, help me with my confusion. So did you create a new post for me from what I wrote above? If not, HOW do I start a new thread? All I can find is starting a new conversation. I'm an old man who's sight is going, hearing is pretty much gone already. My ability to become highly frustrated over things that should be simple that are not is still working 100%
Coug
4,796
Olympia/WA
In the main page for generator threads at the top right there should be a button for "Post Thread" that will open a new page to start your thread
I've been here a long time so not sure if that is something restricted on new accounts or anything like that. If you can't see that button, then hopefully one of the moderators can help you out.
Guyfang
27,256
Burgkunstadt, Germany
If you need help, type this: @Guyfang and I will come running!
