MEP-804B Governor control issue
Guyfang
27,331
Burgkunstadt, Germany
I expect the frequency to go high when I have the frequency set for using R2 (which I should not be able to use). Based on what I seen on this generator before. I have to adjust the tuning for the frequency by using the set screw on the A5 when it switches.
What do you mean here? Why should you not be able to use the R2? And you should NEVER need to adjust the set screw on the A5.
jbcirs
Dallas, TX
Thats a real possibility. The A5 works. It holds steady frequency. Just before things go south, I hear strange noises. Where are they coming from, and why are you moving the AM-VM switch all the time?
I took the generator in to have it looked at by a generator repair shop that had a recently retired 91D. After seeing it do its random acting up and running some test he told me, I need to replace the Woodward unit. It's part number 8270-1096. Any idea where I can find a replacement? Or even another model that would work?
He couldn't test the Woodward its self, but he tested everything else connected to it and it all worked fine.
