MEP 805B 806B screen dim/bright tool build
155mm
Chief and Indian
387
Guymon, OK
Going to start on the build for a tool to lighten and darken the screens on the 5/6B's. Finally got the cable from China
I am probably going to use a waffer board to backup, the terminals are open on the back of the breakout board. The pour potting material over the whole thing to dummy (155mm) proof it.
Going to use a double throw spring loaded switch for the up/down bright and then a single throw for the on/off
If there are some smarter electronics guys out there, I am open for design improvement until I pour the potting material.
155mm
Chief and Indian
387
Guymon, OK
Talked with our local radio shack owner, he suggested a job box instead of waffer board and to use separate push buttons instead of a double throw. I thought it was good ideas, here is what i have so far.
Thinking i will get the test runs done tomorrow, then pouring potting epoxy so suggestions better be quick
Guyfang
23,001
Burgkunstadt, Germany
I think you got good advice from the radio shack dude. Two separate push buttons seems like it is more foolproof. Don't fill it until you have done multi runs, on several differant CIM's. But all in all, looks good!!!
155mm
Chief and Indian
387
Guymon, OK
Thanks. I am surprised that noone else has done this. The army way of building a tool was a good way to smoke a CIM because you have a chance of getting the wrong wires out of the 100 wire loom. My build is fairly fool proof even for a dummy like me.
I only have 2 available locally, mine which doesn’t need adjusted but the other jenny is brand new, like 12 hours not a reset, its CIM is unreadable without the dash lights on. So I will tear down its plug and tape then adjust the screen
155mm
Chief and Indian
387
Guymon, OK
Ahahhaha, it vurks.
it will adjust to full white and full black. 40-50 button pushes from full dark to full light. I dont know if my backlight switch works or not, the sun is too bright, will check that this evening when it gets dark.
Now off to town to see if I can fix the other machine, that will make the owner very happy. He didnt know that he had a problem, whomever sold him the genny, at a premium, was not truthful at all. Seller told buyer, oh thats just how its supposed to work, liar liar pants on fire. I dont know who the seller was, but there are some other things I want to bend his ear about as well. Thats why I hate used car sales men, whatever it takes to make the sell, even if they outright lie about it.
M35A2-AZ, when this gets epoxy, it will be in the mail to you to fix yours.
155mm
Chief and Indian
387
Guymon, OK
here is a video of the tool at work.
https://youtu.be/Yyv2Xf-616g
remember the mouse will not work, and the reading are not correct, this tool is for contrast only.
When verifying that the back lights are working correctly, look at both sides on the top and the bottom. There are 2 separate back lights in the CIM
Video was taken in the shadow of the shop in the shadow of a truck. In direct sunlight the screen will washout much worse at lightest contrast setting.
I did use some 1" standoffs on the bottom of the breakout board to center it in the job box
Farmitall
276
Eubank, KY
View attachment 711194View attachment 711195
Great job!
May I ask why you feel the need to pot this?
155mm
Chief and Indian
387
Guymon, OK
I am a bull in a china shop and the breakout board I didnt think was skookum enough to be wiggling around with the 100 pin hanging off the end. Dust, dirt, wham bam thank you ma'am of having to be around gunbunnies my whole green iron career. Build it 10x stronger cause some dumble dorf will use your special tool as a toothpick and jump rope.
Farmitall
276
Eubank, KY
If you feel your device has to be potted, I don't think it's cased and/or interfaced with the outside world correctly.
Yes potting may be cheap and expedient, but it just transfers stresses to other parts and prevents any future serviceability.
Potting is usually done as a security measure or thermal stabilization measure on highly temperature sensitive circuits/components.
Potting for physical damage just makes it heavy and even more likely to be used as a hammer.
Guyfang
23,001
Great job!
I would have done the same.
1. You never need to get back into the board. No parts that need replacing.
2. The tool will not get enough use to somehow cause a broken wire in the bottom plug, so once again. Its protected.
3. If you drop it, its protected.
4. If I need to get my assistants attention, I wack him on the head with it, and its protected.
Guyfang
23,001
In the military, potting is done to keep people from screwing things up, by "repairing" it. Its also done to protect the manufactures product.
kloppk
3,209
Pepperell, Massachusetts
The MEP-805B / MEP-806B CIM Brightness adjustment cable/tools I'm fabricating will be ready to ship this weekend.
Feel free to PM me if anyone is interested in one.
155mm
Chief and Indian
387
Guymon, OK
Did you build one for cjohnson?
