MEP 805B CIM Replacement
I can't get the CIM to power up at all, It is getting power to it, But I can't get the unit to do anything. When i pulled it to bench test the unit I did find water in it, so i drained it and let it air dry for a couple of days. But I still can't get anything out of it.
155mm
Chief and Indian
387
Guymon, OK
Have you read this thread?
I did try the panel light and all I get is a black screen. To me it looks like it's not booting up. I unhooked the 27 pin cable from the back of the CIM and still nothing. I'm thinking its a dead CIM. I found one on eday and i'll see if that one will works.
Guyfang
23,052
Burgkunstadt, Germany
1. Have you ever seen this gen set work right?
2. Have you downloaded the TM's from the TM forum here in SS?
3. If so, did you try to work through the troubleshooting diagram?
