MEP-805B filters and fluids
Gary27701
Maryland
Hello,
I just got one of these critters, and am looking forward to getting up and running as a whole house standby generator. I am a civilian so please be gentle while I learn the lingo.
I'm pulling my hair out in looking for part numbers. Are these the correct numbers?
- Per TM-9-6115-671-24P (cage code, part #)
- Fuel filter 72850 479735
- Air filter 18265 P18-2059
Per TM-9-2815-259-24P (cage code, part #)
- Oil filter 33968 36881696 (fram PH8476 ?)
Or, can I use the details for the John Deere 4045T engine? Please feel free to suggest alternate commercial part numbers.
For oil, I think 15 quarts of 15/40 API CI-4. Am I correct?
For coolant, is any heavy-duty diesel antifreeze ok like "motocraft VC7B" or similar extended life coolant? OAT vs NOAT? Diluted to 50/50?
Regards,
Gary
155mm
Chief and Indian
387
Guymon, OK
I thought we had a cheat sheet of over the counter parts for the gennys by model, was i just dreaming that because i cant find one
Guyfang
23,347
Burgkunstadt, Germany
Yeah, yeah, yeah. I started one. Just havent got it finished, and can not for the live of me remember where I put it. Give me some time. I might have the info for that type set.
Gary27701
Maryland
Here's what I found as well for filters.
Fuel filter
- John Deere - RE60021
- Baldwin - BF7675-D or BF7675
Oil filter
- John Deere - RE59754
- Luber-finer - LFP5757
- Baldwin - B7125
Air filter
- Fleetguard - AF0173300KM or AF1733KM
My only remaining question is about antifreeze. Good ol' green or one of the extended life coolants rated for diesels like Motorcraft VC8?
155mm
Chief and Indian
387
Guymon, OK
You are trying to start a fight with the antifreeze question? Hahaha
that is like asking what oil is best,
if you do regular maintenance on the antifreeze all antifreezes are the same
Gary27701
Maryland
hehe... don't need one of those discussions. ;-)
Let me rephrase my question, "are the John Deere published 4045T engine specs valid even though these engines are used in the military?". If so, that answers fluid questions, and then I can use the more conservative hour or clock time for when to change things. FYI, I would also be testing the engine's oil like I do for my F250 SuperDuty.
