- 17,954
- 26,875
- 113
- Burgkunstadt, Germany
ABEZ | GRIPPING ACCOMMODATION TYPE | ANY ACCEPTABLE |
ABKV | OUTSIDE DIAMETER | 4.625 INCHES NOMINAL |
ABKW | OVERALL HEIGHT | 1.500 INCHES NOMINAL |
AGEJ | SYSTEM FOR WHICH DESIGNED | PRESSURIZED |
AGEX | CAM QUANTITY | 3 |
AGEZ | RETAINING DEVICE TYPE | CHAIN |
AJQT | RETAINING DEVICE LENGTH | 7.000 INCHES NOMINAL |
ALGN | PRESSURE RELIEF METHOD | MANUAL |
BPHD | MAXIMUM WORKING PRESSURE | 3.000 POUNDS PER SQUARE INCH |
CBBL | FEATURES PROVIDED | BREATHER HOLE AND SUBMERSIBLE |
CQST | FILLER NECK DIAMETER FOR WHICH DESIGNED | 2.375 INCHES NOMINAL |
MARK | SPECIAL MARKINGS | VALVE INSIDE,OPEN-NORMAL CLOSED,FORDING-VAPOR LOCK |
MATT | MATERIAL | ANY ACCEPTABLE OVERALL |
PRPY | PROPRIETARY CHARACTERISTICS | PACS |
SFTT | SURFACE TREATMENT | ANY ACCEPTABLE OVERALL |
STYL | STYLE DESIGNATOR | OUTSIDE CAM TYPE |
ZZZT | NONDEFINITIVE SPEC/STD DATA | 2 TYPE |
Above is info on the cap.
We used liquid simple green to get oil out of the radiator. Seemed to work well.
