MEP-805B Voltage off
SteveTheGreen
Oklahoma
This generator starts and runs. But the voltage is way off. See pic.
Phase 1 is 209, phase 2&3 are 109.
I've swapped voltage regulator and no difference. Any ideas?
Sent from my SM-G960U using Tapatalk
peapvp
1,226
Basehor, KS
Last year you presented us with the same problem.
DieselAddict asked you on May 13th, 2021 if you had actually measured / verified the in the CIM indicated voltages with a volt ohm meter on the generator output posts
Link to original thread
Have you since been able to actually measure this with a meter in 18 month?
we cannot help you until someone has actually measured the voltage on the actual output posts
