Good morning everyone,
Been fighting this issue for a couple weeks now. I've got two gensets with an identical issue. Both generators are running rough and surging. The actuator LED on the Speed Control Unit is pulsing in time with the engine surges. So far I have replaced the batteries, removed and inspected all of the electrical connections in the box behind the control panel, replaced the MPU with a known good MPU, replaced the fuel with brand new fuel, replaced the air filter and replaced the fuel and oil filters. I also wired the fuel actuator straight to 12VDC to bypass the governor system and the engine runs normally in that case. I have all the applicable TM's and schematics available from LIW and here (thanks Guyfang) and cannot find anything in the literature mentioning why the actuator LED would be pulsing or a troubleshooting track to go down with it. One TS track does mention it and just says the speed control unit is bad, so I replaced it with a known good one and the same fault remains.
I looked through every thread here on the MEP-806b (and the 805b because, hey why not) and havent seen this issue mentioned yet. Any insight from the folks here would be much appreciated!
Thanks in advance!
Thanks in advance!
