Hi -
Thanks @kloppk I received the new board and bolt and got it installed - no issues. I just got this unit (18 hours). Haven't got it started yet. I replaced the governor control as everything I have read says high probability of failure, drained old fuel, and replaced with new, and drained water/fuel in filter clear bowl. I also pulled the fuel line to the injector and it is getting good fuel flow coming through.
I started tracing through the TM but was curious how the governor actuator mechanically is supposed to work? I've attached some pictures and a video link of trying to crank it. The arm doesn't move at all. I lift it up and still doesn't fire. Feels like there is something electronically causing it not to fire. Any ideas?
Also, this one had a battery in it with 11V showing, any luck with reconditioning? I'm using two (2) car batteries in series to attempt starting so I have good power.
Video: https://youtube.com/shorts/dyylYeWsrOc?feature=share
