MEP 831a Hard line cracked
Quattro210
Texas
Hey guys, I have a MEP 831a and saw a little fuel leak above the injector pump, went to inspect and noticed that the hard line that runs up from there to the injector has a hairline crack in it. Ive searched through the generator manual and the engine manual and cannot locate a part # or NSN for that hard line. Anyone have a number for it? Appreciate any info
DieselAddict
1,900
Efland, NC
I recommend taking it off and going to a local hydraulic shop for a replacement. They should be able to knock it out cheap and quick.
Here is a page from the LP master parts manual. That should point you in the right direction.
DieselAddict
1,900
Efland, NC
I don't have the manual for the Yanmar L70 here. You can find it online and see about the part number for the injector line. The same advice to try a local hydraulics shop still applies.
DieselAddict
1,900
Efland, NC
Yea, I was busy trying to get an investigation report out to a client so I didn't have any more time to go searching. Got to keep them making the medicine.
csheath
197
FL
Can you pull it off and weld it? I have cracked a hard line on my backhoe hydraulics and welded it with success.
Kenny0
30
Leland, Iowa
I did do that once in an emergency, but I would recommend not to. Any foreign material left after welding or brazing that can't be cleaned out could go right into the injector, and they wouldn't like that. The inside of the injector line is very small.
