Mep 831A load issues
2Pbfeet
1,530
Mt. Hamilton, CA
I'm glad you got the muffler cleaner!
Congratulations on having scored a brand new second engine. As it is new, (ish?) I wouldn't load it up too much in the first 5-10 hours, though I would vary the load, I would take it to full load, just not for very long, and I'd change the oil between 10-20 hours if it were a new Yanmar, but I don't know about the military stored and preserved engines.
I do find it a bit troubling that the rebored and honed engine is already wallowing out and wearing that part of the cylinder wall. That seems way too fast. Was anything besides the piston and rings changed? Connecting rod? Pin? Was the crankshaft checked for alignment and / or damage? It does make me wonder about which came first, the chicken or the egg...did the rings break because something was out of alignment from the factory (and still is), or did the rings breaking cause the other issues? Or...?
You have quite the saga here.
All the best, 2PbFeet
grywitt
245
Nm
I was pretty disturbed by that myself. I think that's less than an hour of running and it already looked like that. When I saw that I thought for sure the rings were going to be wrong. But no. I will have to say no to all of those questions you had. The rod piston pin ect are all the same pieces. The crank shaft seemed okay. Definitely wasn't checked for alignment though. I wouldn't know how to do that. Figuring out the answer to why that's happening is outside my knowledge and skillset. I was wondering if maybe the oil pump system isn't working right? I had oil at the rockers ect though.
This has been interesting for sure. Every smoking gun i find and I think ha ha. This will be it for sure. Then nope. The engine turns easily by hand and doesn't feel like anything is binding or dragging. I'm pretty lost. It will be interesting to see how this other engine works. I will follow your suggestions for break in. A small amount of oil came out when I pulled the plug to install the drain valve and temp sensor. I'm not sure what kind of oil it was. After putting the oil in it I held the compression release and pulled the start cord a bunch of times to try to get some oil circulating. Hopefully it primed the injector too.
I'll update this thread that doesn't end as things progress.
2Pbfeet
1,530
Mt. Hamilton, CA
As you point out, you had oil in the rockers, and no signs of wear there, or elsewhere, other than that patch on the cylinder wall. When the oil pump/system isn't working, the engine doesn't get very far. I don't think that the one sided wear is an oil issue, it looks to me like an off axis alignment issue, which I've never seen in person. Usually if something bends anything in the pin/rod/crank axis, something rather catastrophic results. Based on the fact it is a patch part way down, I'd wonder if the crankshaft was off, but I really don't have a clue.
Keep us posted.
grywitt
245
Nm
Okay update.
As of right now the new to me engine has been running for 3.5 hours at various loads. I've been changing the load about every 15 minutes.
I started at 500 watts for a few minutes then 1kw for a few minutes then gave it 1.5kw for 15 minutes. Then 2kw for 15 ect. About the 2kw point I tried 3kw for a short time while I was there to see what it would do. Run 3kw is what it would do. A little smoke but not much. I did try 3250 just to see for like 30 seconds and it held but smoked pretty good. I've been fluctuating between 2, 2.5 and 2.75 loads.
I did let it warm up for about 10 minutes before any loads. It does smoke a little at 3kw but not much but I'm trying for no smoke. I think this would be the 3000' elevation showing up.
So now I'm really curious what's up with the other engine. It has never ran like this. I wonder if there is someone that makes YouTube videos that wants to disect this problem. I really want to know. Heck I might have it fixed and not know it but I don't think so. Maybe one day if I get bored I'll put it back in the gen and see what happens.
I'm going to run this gen all day changing loads maybe hourly now. It's at 2750 right now and purring. I think I'm seeing how this 831 is supposed to run.
grywitt
245
Nm
Some interesting things I'm finding reading the manual. First I didn't check the parralelity of the rod. Maybe I should check that. Also the description of the rod and which engine it goes in don't match what I have it says the L70 gets a through bolt and I have the push bolt. Maybe it's nothing but I think it's time to explore all possibilities now. Oh and has anyone heard of selectivery?
Update on the machine. It's been running 5 hours now and the last hour has been 2750 with basically no smoke. I'm going to go run it at 2250 for an hour.
grywitt
245
Nm
Hello
Get a dry, clean, empty milk gallon jug.
Pull the supply line off the injector feed side of the filter. Attach a tube long enough to get into your jug. Flip the switch to prime, and that jug should be pretty close to half-full within 60 seconds and have a decent spray with each pump stroke.
If the spray is weak, or feeding very slowly, start looking at the filter, strainer (little metal can attached to the filter), and finally the pump itself. If you get to the pump itself, the main pump and aux pump are interchangeable-- switcharoo.
Another thing to try is pull the return line post injection pump and injector. Put that into your jug (with everything else connected properly) and start / run the engine. You should still be getting damn near 1/2 gallon a minute returned on idle.
[/QUO
Hello. Quick question. I see the spot for adjusting the frequency. Do you just dig out that back plug? Then is it just a small termination screwdriver? The frequency is at 59.3 but I might as well make it perfect if I can.
Thank you Gary
2Pbfeet
1,530
Mt. Hamilton, CA
My guess is that is a japanese to english translation issue. Selectivery=selectively. My recollection of the manual is that it has a few gems.
Can you find a part number on the conn rod? (FWIW: I have never seen a through bolt version.)
I'm glad to hear that the replacement engine is behaving as one would expect!
grywitt
245
Nm
I'm glad to see it working correctly also but it honestly doesn't feel like a win. Heck I threw an entire new engine at it. I did reassemble the engine and put oil in it because I don't like the idea of the engine sitting there dry. I think i will end up draining the oil and disassembling it again though. I want to check everything. I didn't see a direction the rod went for sure. It looks like it's the same both ways and I didn't see marks to know. I did put it back in the way it came out but maybe it was wrong. I don't know. I'm hoping to build a shop soon and I'll be able to be more organized and clean.
grywitt
245
Nm
When
When I look at my pictures when I took it apart and the way the book says to install it i think the rod might be backwards. To look at it it doesn't look like it would matter but it does say to turn it a certain way. It looks to me like it says the flat spot with the 106 should be towards the fuel pump side and it wasn't
grywitt
245
Nm
Okay. I think this thread can end.
I don't have 831 load issues any more. I just ran it for over 6 hours at lots of loads and the last half hour was at 3kw. At the end of that half hour the gens was just slightly puffing a tiny bit of smoke but not an issue and it held fine.
Unfortunately the fix was a whole new engine but I do still have the original and it was low hour and still a mystery to solve. Maybe when I explore that problem Ill start a new thread.
Funny I've seen the 831s sell for what I thought was some ridiculous amounts but the only difference is they spent it all at once and I spred it out. Ha ha ha. I do still have a lot of parts though.
Thank you to everyone who helped me try to get this fixed.
vrzff
160
33
Mont Vernon, NH
I'm glad you got the right result, even though it took another engine.
The troubleshooter in me would tear down both engines, and compare what's going on side-by-side. I just want to KNOW, especially on something so weird like this-- add it to my encyclopedia of stuff.
I'm seriously thinking what PB mentioned earlier about something being out of alignment. Bent / warped connecting rod? Cylinder bore out of round? Piston out of round? Thrust washer on the crank / crank not aligned with bore?
I can't ask you to do this, especially after everything you've been through. I'm really just curious.
2Pbfeet
1,530
Mt. Hamilton, CA
I
Sometimes, a win is still a win, plus you have a puzzle on the shelf to figure out when you get a round tuit. I'd also add all the knowledge that you gained by working through the problems. That's a solid win in my book.
If you do decide to go after your puzzle, I think you have an interested audience ready to follow along.
Congrtulations again on getting it running, and for scoring a low cost new replacement engine.
grywitt
245
Nm
Thank you to both you guys. You are correct 2Pbfeet I definitely didn't come away empty handed and gained knowledge and still have a project. I was looking at these two engines and noticed the full throttle bolt on top has a tamper wire also. My bottom wire the lead was still there but it was dangling when I got but the top one never had it. I was noticing on the new engine i couldn't move the throttle all the way to start on the new engine and on the old one it never touches that bolt. Hmmm.
That wouldn't explain the cylinder wall but it's interesting.
Vrzff I will be tearing into this again because I have to know too. The cylinder was just bored .5 over and I was .01mm away from round before I had it bored so I don't think I'm out of round. I didn't remove the wrist pin the way the book says to but I don't think I warped the piston and it's the same spot as before that it's wearing.
I've spent a lot of time playing with this toy lately so I need to move my attention. I'm going to put the skin back on this gen today and move onto some other things before I start my new job Monday. I will start a new thread ( stubborn Yanmar L70 ) when I start digging in.
Thank you again
grywitt
245
Nm
I do feel really lucky to have gotten what I'm pretty sure is a brand new engine because the pull cord wouldn't retract. You never know why it might be in the crate. That's definitely a win.
grywitt
245
Nm
Okay. One more update. I can't help myself. All the times previously that I thought I fixed it. When I got it fully reassembled it would laugh at me and say just kidding I'm still not right. Ha ha.
So today after completely reassembleing the gen minus battery terminal covers. They are coming. I ran the gen again. It performed perfectly. I ran it for a couple hours at various loads with another half hour at 3kw. The actuator is working right it starts and stops without issue. I think i really do believe it's fixed
Heck even the battery charger seems to be working. It really is a nice little gen and pretty quiet too. The cover has been smashed a bit somewhere and the cover doesn't fit perfectly but I can live with that. I adjusted the frequency to 60hz exactly (thank you vrzff I didn't know it was adjustable). I almost need to buy more of these gens since I have learned so much about them and have so many spare parts now.
