- 2,335
- 4,214
- 113
- Massachusetts
When you have time and you've charged you batteries please do the following test.
Leaving S1 in the STOP position lift the actuator off the magnet. Press the compression relief lever. Pull start the set. Measure the AC voltage across the A & B terminals on the Governor Controller.
Shut the set down by moving the actuator back to the magnet.
