MEP-831A Overvoltage
Clay James
Reno/NV
I'm having an overvoltage issue on my MEP-831. Ive searched and haven't found anything about my specific problem. It is producing too much output. It will get up to 150v on the 120v circuit and it's dependent on engine RPM. The higher it revs the more volts it puts out. Could it be a voltage regulator or governor? It won't trigger any faults even with that voltage. It's a lower hours unit and it only had about 50 hours on it when I got it and I haven't used it much.
Chainbreaker
1,869
Oregon
If I owned a MEP-831 I would replace the "known problematic governor" with one of Kloppik's units even if the generator was currently working well. His governor unit is reported to make it a much more reliable unit and less hair pulling down the road.
DieselAddict
1,903
Efland, NC
Has the unit operated correctly in the past and this is a new problem?
Have you traced out the wires between the voltage POT and the inverter?
Light in the Dark
5,513
MA
Do the 831s have adjustable throttle cables like the other machines? I just diagnosed an 803 that kept giving me an overvoltage condition... turns out someone messed with the stops for the throttle and it actually WAS producing too much voltage. Have you tested this machine with a handheld tester, as well as onboard gauges?
I fixed the stops, readjusted the throttle cable, and it now runs properly with no overvoltage condition (which at least now I know that this machine is also fully functional in terms of the safety limits in place for this condition... they worked properly).
DieselAddict
1,903
Efland, NC
No throttle cable on these. The throttle is servo controlled. Also the output power is via an inverter so not directly connected to the alternator.
If the voltage is going up and down with engine RPM its either a bad inverter, bad voltage pot, or wiring problem between them.
dav5
182
Mono, Ontario
831A's are a real PITA. I 2nd the suggestion to first of all get one of Kurt's controllers. My second suggestion would maybe to consider selling it and buying an 802A
Clay James
Reno/NV
Got messing with it again finally. I adjusted the speed setting on the SLC100 and it brought it down to the correct voltage but not close enough where my inverter would connect. It was surging and acting funny too so I'll start with replacing it since that seems to be the problem.
