MEP-8xx Battery Information
csheath
215
FL
Mine is going to get lawn tractor batteries next time. The Value Power group 26 batteries are limping along for now. One of them has low hydrometer readings but my solar charger is keeping the pair above 24V for now. Having the solar controller mounted on top of the unit under my shed has been a good way to monitor. My little tractor is parked beside it so every time I use the tractor I glance over at the generator battery voltage.
USAMilRet
15
Tampa, Florida
I just bought a set today. Don't need much for Florida. Only a six month trade out but you will know by then. They are about 1/2 in fatter then the 51R. Should fit nicely in the 803. But for $60 each better than $125 car batteries.
My other set has sli51r in them but only 400 CCA and they are working fine. One bat is 1 year the other half that.
Anxious to see if the sli22nf will be a good choice.
boxer4luvr
NC
Indeed... please keep us posted. Do you use a battery tender/trickle charger, etc?
Otto the man
NE Ohio
Just an FYI, Rural King has Exide 51R, 525 CCA rated (Both mine tested out over 590 CCA) for $59.00 with a $12.00 core charge. Pretty decent price.
boxer4luvr
NC
Also FYI - Batteries + Bulbs has the SLI22NF Duracell Ultra for $59 with a $10 core charge. Not vouching for the product, just doing some internet searching.
