- 18,134
- 27,230
- 113
- Burgkunstadt, Germany
That's the problem with riv-nuts. no give. And often, putting these things back together requires some give, to get it to aline.
Howdy,
It will depend on what part of the country you are in. Fastenal has all these pieces for ordering.
#10-32 x 1/2" Hex - Unslotted Drive Indented Hex Washer Head Grade 18-8 Stainless Steel Machine Screw
https://www.fastenal.com/products/details/0174583
#10 18-8 Stainless Steel Medium Split Lock Washer
https://www.fastenal.com/products/details/1171059
#10 18-8 Stainless Steel Small OD Flat Washer
https://www.fastenal.com/products/details/71009
#10-32 Grade 18-8 Stainless Steel with External Tooth Lockwasher K-Lock Nut
https://www.fastenal.com/products/details/1170923
1/4"-20 x 3/4" Hex - Unslotted Drive Indented Hex Washer Head Grade 18-8 Stainless Steel Machine Screw
https://www.fastenal.com/products/details/0174594
1/4" 18-8 Stainless Steel Small OD Flat Washer
https://www.fastenal.com/products/details/1171013
1/4"-20 Grade 18-8 Stainless Steel with External Tooth Lockwasher K-Lock Nut
https://www.fastenal.com/products/details/1170925
Howdy,Thanks. I just ordered enough to take care of most of the bolts and nuts on the cabinet. Jeesh stainless steel is expensive...
But thanks for the research and where to get them.
Thanks Daybreak....
hi thanks for the list , I want to verify - which are these ?Howdy,
For those thinking about swapping a bunch of the screws on your MEP-802/803
MEP-8xx stainless steel screw information
The main screw used 80% of locations on the panels
The other large screws are
The look is the exact same which you have currently. The main #10 screw at some locations use just the screw itself, some with a washer, and some other with a lock washer and washer.
I ordered the below, because of the size of packs they sell.
50 #10-32 x 1/2" screws
50 #10 washers
50 #10 split lock washers
50 #10 nuts w/keeper lock (The amount will depend on what year your unit was built) Some year they switched over to having a majority with cage nuts.
This still might not cover them all. I do not know the exact count that you will need.
The larger ones will be around 20 pieces.
