mep002a/3a electrical clean up and fixes now
robkiller
Colorado Springs CO
So I have a few more questions
For Mep002a/3a series gens
So finally have all of my gens running strong.. now…
  1. How do you determine the speed of the motor? Need to set max and min speeds
  2. Does the throttle need to be all the way at full to function right or just so the hz are at the proper 60hz?
  3. I have a hz meter that won’t move on one of the gens. What normally causes this?
  4. I have one gen that is not giving more than 60 v ac at the front plug and wont adjust with the adjusting knob. It also appears that it’s not charging the battery. Are these related or am I looking at a few problems? I know that means the dc regulator/stator is most likely bad but what else am I looking at for the ac side of it?
Thanks!
Triple Jim
277
North Carolina
1. If you have a Kill-A-Watt or other frequency meter, the engine speed is 30 x frequency (Hz).
2. Throttle should be set at 1800 rpm and left there. It doesn't have to be all the way out at 1800 rpm.
3. If you've verified that the generator is putting out proper voltage and frequency, then a non-functioning meter means the meter or the transducer or the wiring is bad. If you haven't, I've found that my frequency meter is very erratic if you're very far off 60 Hz, sometimes reading at the low end of the scale, and sometimes the high end, but not related to actual frequency. Once you're near 60 is works as expected.
4. Battery charging and AC output are not related, as long as the engine is running halfway close to 1800 rpm. Low AC output could mean bad wiring, a bad rotating diode, a bad generator winding, a bad transformer, possibly a bad regulator, etc..
robkiller
Colorado Springs CO
Thanks what leads or location do I check the hz? My meter will do that but I don't know the best place closest to the source to start testing the hz.
Coffey1
493
Gray Court SC
I know on my o4A if you throttle full up you. Will trip over speed and kill engine until you reset it
Speddmon
Blind squirrel rehabiltator
Cambridge, Ohio
If you have a multimeter that will measure Hz, just use the convenience outlet. It's close to the control panel and the safest place to do the test.
Isaac-1
SW, Louisiana
Most often when there is a problem with (mostly cheaper) multimeters they will read roughly some multiple of the actual frequency, so if you see something like 189 hz you should KNOW that the generator is not running at over 3 times its rated speed, your clue here is that the pistons are still on the inside of the engine.
robkiller
Colorado Springs CO
So that makes since that 60 hz is 1800 rpm. That will help me get the speed right.
For low ac what would be the first thing you would start to check?
robkiller
Colorado Springs CO
I found the mep003a has a low speed setting of 300 and top setting of 2000
But i also found the mep002a says low of 1600 top of 2250
Is this a typo are they that different?
Any suggestions on what you would test first and how? To try and figure out why I am only getting 60 volts ac out of the front plugs?
Speddmon
Cambridge, Ohio
It is a typo. The governor should be set somewhere between 1600 on the low side to 2000 on the high side.
As for where to start, I would suggest the troubleshooting section of the -34 TM. Particularly page 2-10.
