I am not 100% sure exactly what your problem is. If the solenoid that retracts and lets the IP throttle arm move up is not retracting or is not retracting fully, the engine will not get fuel and it will not start. If the solenoid fully retracts but the IP arm does not move up freely, the problem is probably varnish etc inside the IP which is binding the IP arm. I do not think the solenoid is meant to be repairable, but some on this site have had success spraying the solenoid shaft with PB Blaster and working it up and down. Several months ago a poster wrote a thread about removing the solenoid, opening it up, and repairing it. If the solenoid is not retracting, you may do a search. I think one of the two things I mentioned above is probably your problem.
PS: I had a 002A that the throttle linkage was binding where it goes through the oval hole in the sheet metal above the IP. Even though the solenoid retracted the IP arm would not move. A bit of filing the hole with a rat tail file did the trick.
