mep002a
Guyfang
27,129
Burgkunstadt, Germany
Then try this. Start the set and put it on a small load. When it kicks off, try and re excite the set by placing the S1 start switch in the start position for 2-3 seconds. See if it starts making power again.
also. Have you tried BOTH of the AC volt regs?
rpjuneau
Louisiana
I only know of one ac voltage regulator inside the main control console. where is the other located. also have tried to field excite by holding start position for 2-3 seconds. no luck
Chainbreaker
2,112
Oregon
I think Guy means replacing the Lakeland one by swapping back in the other one you took out. If it behaves the same with either AC reg board it would be very unlikely that both AC volt regs would contribute to the exact same issue.
Also, are you saying that you have attempted re-exciting it "after" AC drops out without shutting down by moving S1 to Start while its still running (there is a centrifical lock out while running so it doesn't re-engage starter) and you are saying it didn't help restore AC output?
rpjuneau
Louisiana
I tried to re excite the field Friday afternoon. Using the S1 switch by holding in start position, no luck. I will try changing out the new board, and putting back in the old board for the ac voltage regulator.
Philratcliffe
9
Florida
I’ve had my 002s stop making power I am 30 mts from the ocean I have a hotel here. The first stator failed. It also cooked a couple of diodes in the bridge rectifier. I had the stator rewound replaced the diodes amd then worked fine again. It’s happened to all three of my 002s. Just remove the front stator only held on with 8 bolts.
