Mep002a
jeepin
12
Vermont
What did you use for fuel filters? I am under the impression the NAPA ones dont fit right?
I removed the three Fram cans, fabbed an angle bracket and added
a Wix 33123
with a WIX 24309 base. You will also need 1/2 to 1/4 NPT bushings to re-use the stock AN 90degree hose elbows with that base.
jeepin
12
Vermont
Mangus or anyone else, does your battery condition gauge read with the engine stopped or only when the set is running? I am trying to troubleshoot my no charge condition.
thanks
mangus580
282
Western NY
I'm not really sure yet. One gauge isnt working, and the other has only been run from a slave cable.
It almost would appear neither are charging, but I havent looked far into that.
What makes you think yours isnt charging?
jatonka
87
Ephratah, New York
I can't speak for the 5 K sets, but on the 10K, the voltmeter guage only reads when the motor is running. at idle the guage reads about 10 to 11 volts, at full RPM, making 60 Hz and 120 V. it reads about 25to 27 volts, in the green, heading toward upper red. I have been running it a lot and it is charging. I am putting a solargizer on it Saturday to keep the batteries up and desulfated. I found a brand new 101 trailer cover for it today in one of the hooches, it fits great, just isn't quite long enough. If anyone has a 116 gen cover that they want to trade for a 101 cover, I'm willing. JT out
mangus580
282
Western NY
Good to hear you got hours on it JT.
I think my first step is to get good batteries on them. Then I need to work from there.
If anyone tries to use the original fuel filters, let me know what cartridge you use, and how it fits.
jeepin
12
Vermont
The alternator fuse is blowing.
aboonski
West Melbourne Florida
I just won one of these at Redstone. The pictures are helpful to me because I need to bring along a spare tire when I retrieve the unit. Looks like the M1008 rims will fit this trailer.
dirtyfingernails
Gainesville, FL
The NAPA fuel filters work fine for the MEP003s. That O ring is a pain to install though! Alan, glad to see you got one. How much you guys paying? I bought before the glut and probably paid too much (about $1200 per).
Steve
aboonski
Hi Steve, after all the add ons by GL the total came to $888.94 for the unit that I won which has the trailer and bows with the generator. I hope I didn't screw up because I did not have my correct email address in my profile. I only found out that I won the lot because of the charge showing up on my credit card; for some reason the $888.94 disappeared from my card today so I don't know at this point! I went ahead and sent in my EUC and emailed the main office with an explanation. Anybody else do something like this?
dirtyfingernails
Gainesville, FL
Mangus,
No problem. I used NAPA 3113. You do have to slightly modify the filter. You see the "T" shape in the center of the filter housing? Those "tangs" have to bent slightly to fit over the MEP003 fuel filter center bolt. No biggie for me. It's a whole lot cheaper than a specialty item too. I've stocked up on them. Smok Stak is where I where I got this information.
Steve
aboonski
Anyone know the approximate weight of the genset and trailer combo? Brinhing the lady along for the ride to retrieve my 5KW and we are substituting the Toyota Highlander Hybrid for the M1008 (for confort reasons mainly). Just concerned that the weight might exceed the towing limitations in the owner's manual for the Toyota. Also want to find out if the trailer is an M103 - I'll post a photo. Thanks!
