MEP003 Help
BBELL
Mobile/AL
I have a mep003 that is putting out 160 volts and can't control it with the rheostat. I got the old one to work shortly so i figured it had a bad rheostat. I installed a new one today and no luck still no control. Thanks for any help!
Isaac-1
50
SW, Louisiana
It is probably the voltage regulator, I am fairly sure the voltage regulators on the MEP-002 and MEP-003 are designed to fail at full voltage, there is a trouble shooting and repair section in the tech manuals.
Ike
BBELL
Mobile/AL
Thanks for the help so much for simple fix! I will have to read up. Is there a common problem on the regulater that might stand out?
DieselBob
13
Arnold Maryland
Check out TM5-6115-585-34. pretty good step-by-step trouble shooting. Start on page 2-11 step 18 for "HIGH GENERATOR OUTPUT VOLTAGE (NO LOAD)."
Carl_in_NH
Wilton NH
Yes, the common problem with the regulator is a failed output transistor that suffers from a collector-emitter short circuit. It's a $1 part to replace, and really simple if you've got a friend that's into electronics and repair.
Speddmon
Blind squirrel rehabiltator
Cambridge, Ohio
looks like the others have beat me to it....you got a bad Voltage Regulator. Easy fix and probably cheap. Full schematics and component values in the TM. Good luck, and keep us posted
BBELL
Mobile/AL
Finally got the voltage regulater back and in. I am ready for hurricane season now. It works perfect! Thanks for everyones help!
Brian
1,172
Did you repair it or replace it? Where did you buy parts?
BBELL
Mobile/AL
I had it repaired at a local shop. I can find out all there Info and post it. They also found someone to rewind my 005 voltage regulater main transformer (Said it was to difficult for them). They seem to really know there stuff and have alot of connections.
Brian
