Mep003 Putting out 300 VAC and stalling
Davon
Grifton, NC
Shows 300 volts on control panel and I verified this on posts. Stalls after running a minute or two.
I'm thinking bad voltage regulator, but open to any other ideas.
I tried finding the page in the TM about testing the ac voltage regulator, but couldn't.
I appreciate any help you can give me. Thanks in advance!
glcaines
2,830
Hiawassee, Georgia
Welcome to the Site
You stated that it stalls after a minute or two. I'm assuming that you mean that the engine quits running? If so, you have more problems than just the voltage regulator and the high voltage. Is this MEP003A new to you? Have you seen it running previously? If this unit is new to you and has been stored with old fuel in it, have you cleaned the filters in the pumps, changed the fuel filters, dumped old fuel out of the day tank and cleaned out the fuel lines? If not, I would proceed with this prior to trouble-shooting running problems.
For the high voltage problem, as Ray70 stated it is most likely a failed VR. I had the VR on my MEP003A fail and I successfully replaced the failed transistor with one I got from a member here on SS. I then purchased a used VR from Delks as a spare, which I tested to make sure it was a good spare.
kloppk
4,213
Massachusetts
Correct, most likely its the VR.
Typically 1 of the 3 transistors on the VR goes bad.
There is a testing section in the TM, but you have to build a test unit.
@kloppk can better explain the testing and he also offers an upgraded replacement VR if yours is in fact bad.
Also visually check the VR board for burned components.
I've repaired a number of the VR's and besides the three transistors failing I've also found burned out resistors. Obvious charring. The diodes are prone to moisture creeping into them causing them to open up internally. If the diodes have white bodies look closely at them to see if you can spot any corrosion at all where the leads come out of the middle white section of each diode. Any corrosion and the diode(s) have likely failed.
Testing the VR per the TM does require a test box that emulates the electrical environment the VR sees when in the generator.
The test verifies the VR can:
- put out the full load required current when needed
- not leak any current out when it shouldn't under various conditions
- put out the correct regulating current when regulating the AC Voltage
Davon
Grifton, NC
Old post here, but thanks for the replies. I finally worked on it and managed to figure out that the fuel line between the tank and the pumps had a clog in it. It's not stalling now. I did order a new voltage regulator for the other problem. It actually puts out 243 volts some of the time and 300 volts some of the time. When it hits 300 it doesn't change if I move the voltage regulator up. I have some soldering stuff, but I would rather not find out that I didn't do a joint right in the middle of a power failure.
Triple Jim
336
North Carolina
It's probably worth checking the winding resistances of CVT1 per the -34 manual. That transformer works in conjunction with the regulator, and can cause high or low output if something in it fails. Of course the problem is that finding the source of intermittent problems is usually tedious.
Davon
Grifton, NC
I did check the winding resistances by measuring between terminals 14 and 17 on the regulator board. Got 10.5 ohms. It is constantly putting out 300 vac now. I got the regulator already but haven't installed it yet because I did another test where I disconnected wire 17 while it was running. Apparently if the voltage increases when you do this the regulator is "good" per the manual. The voltage was 301 and rose to 336 when I disconnected 17. I guess I will pull a voltage regulator off of my other generator before I install a new one.
Ray70
7,224
West greenwich/RI
FYI, I recently had a customer's machine doing the same thing. I thought it was probably a blown transistor on the VR, but it turned out to be a broken terminal on the T1 transformer. I believe vibration over time eventually fractured the terminal tab off. So if the other VR doesn't fix the problem, take a look at T1 and T2 also.
