MEP005 Questions
Sephirothq
26
Trevorton / PA
I got the pump off, it wasn't too bad. I wasn't expecting the shaft to stay on the engine. I cleaned the pump out there was still a lot of dirt in it. I am going to have to send it out to get it rebuilt.
Did you pull off the front cover where the shaft and gear are? Should I do that before I reinstall it?
weisskr
Dayton Ohio
I just made a thread on this kinda topic and you may want to keep this in mind while pulling this pump.
Here is the link to it.......
MEP005 fuel in the crank case oil - SmokStak
Kevin
leedawg
11
Napa / CA
Kevin
Great post and story Kevin exactly what makes these places useful wish more people would post back their follow up stories. To many just ask for help then do not follow up with what happened and what did or did not work.
glassk
Hampton, GA
try this NSN-- 2910-00-499-0818 PUMP, FUEL: INJECTION
END ITEM IDENTIFICATION 6115-00-118-1240, 6115-00-118-1247 AND 6115-00-118-1248
weisskr
Dayton Ohio
Was just looking at the post and realized I didnt respond to the question about removing the cover that houses the gear shaft.
You can remove the four bolts and inspect but there is not a lot to see in there but it is not required for the pump work.
Kevin
