MEP006a won't stay running
skidunits4you
Washington NC
Help mep006a 60kw starts runs 30 seconds shuts down. still have power to injector pump fuel shutdown, all safety switches seem to be working. no problem with fuel. now what
Ken_86gt
Williamsburg VA
It could be plugged fuels filters or the sock on the pick up line in tank as well. You need to find out if the protection system is what is shutting it down - it should give a light if so, but you never know with old equipment. If it shutsdown when running with the battlefield short "on" it is most likely a fuel delivery/return problem.
skidunits4you
Washington NC
by passed all the safety shut downs today still wont stay running. check all fuel in and returns all good. Had another mechanic look at it with me today and it looks like the IP has a problem will be pulling it and sending it to rebuild shop on Monday. Just fyi I work on these for the town and maintain 16 meps units all set for standby use. Thanks for all the help, I hope I can return the favor sometime.
