Mep803a conversion to single phase
technoid
13
Middlebury center, PA
I just bid on an 803a. I might be the winner. But now i am concerned that this genset cant be rewired to all single phase. Does anyone know if this unit is a 10 or 12 pole? And are there anyone out there who has successfully modified it fir single phase 120/240 volt use??
jcollings
347
Jupiter/FL
Its factory wired for 120/240. Single phase or 120/208 3 phase
Switch in control panel let's you select it.
Sent from my SM-G975U using Tapatalk
Light in the Dark
5,113
MA
Like jcollings said, no worries. The 803 will make 120 single, 120/240 single, and 120/208 3PH. You will select what you want it to produce, via a large switch on the wall behind the fold down gauge panel. Just make sure you are actually bidding on an 803, and not an 813 ;)
jcollings
347
Jupiter/FL
Also don't switch the selecting switch while running............
Light in the Dark
5,113
MA
Yes, doing so might let out that magic white smoke that we all try to keep IN our machines during their lifetime.
technoid
13
Thank you! If i win it i will look for the switch. And yes. Never switch anything while running. I use to repair old Detroits with Delco 3 phase 480 generators that were use for powering well motors. Old school stuff. Old electrics. Im retired.
