Yep mine leaks when just over half full. I'm suspecting the seam on the front side, I can't visually see it with the panel off. I've attempted to remove the tank but that job looks it will have to wait until next spring. So I adjusted the upper float on the fuel level unit to just below half, hoping that when I use the auxiliary fuel supply system, all goes well. Has anyone else seen a similar fuel leak?
