MEP803A Low Voltage
Russ Knight
1,053
Perry, FL
Hello,
I have a dual MEP803A setup and cannot get a voltage reading higher than 212 vac across any combination of outputs on either generator. I have the voltage adjustment maxed. Any ideas?
Thanks,
Russ
DieselAddict
1,903
Efland, NC
How are you measuring the voltage? With a meter at the terminals?
If you have time please measure the voltage at the terminals. L1 - L2, L1 - L3, L2 - L3. Then measure each L1, L2, and L3 to L0.
This will help troubleshoot that your reconnection switch is in the correct position and functioning correctly.
Russ Knight
1,053
Perry, FL
I'm completely ignorant. What is the reconnection switch?
Russ Knight
1,053
Perry, FL
Ok, I know what the selector switch is. I'll check it tomorrow and also write down the voltage across the different legs. I need to make sure this thing is working. We may lose power as a result of the hurricane.
Thanks everyone!
Russ
Suprman
670
Stratford/Connecticut
On the regulator module is a small adjustment screw. I usually set the front panel adjustment to mid range and then adjust the regulator. It's a sensitive adjustment. Only turn it a hair at a time.
Russ Knight
1,053
Perry, FL
Thanks to all who responded. Got both generators dialed in to 60Hz and putting out a full 240 volts. Looks like we're going to need them.
Thanks again, you guys are the bomb!
Russ
Light in the Dark
5,508
MA
Russ
For the sake of future forum questioners... HOW did you fix it? :)
Russ Knight
1,053
Perry, FL
I located the phase selector switch behind the control panel which was set to 3 phase, changed it to 120/240 single phase, and adjusted the adjustment screw on the regulator module.
Works perfect now.
Russ
Daybreak
2 Star Admiral
760
Va
Works perfect now.
Russ
Howdy,
It sounds like you watched the video and said "a haw! I forgot the phase selection" :whistle:
Guyfang
23,030
Burgkunstadt, Germany
Perhaps, in your spare time, you might download the Operaters manual and give it a quick look see. You might not have time later.
