- 18,156
- 27,282
- 113
- Burgkunstadt, Germany
Read the book partner. 2.5-3 volts AC!! The closer to 3 volts the better, but NOT over. When ever the starter clashes, it the mag pick up. No other reason for it to happen.I put varying loads on the genset for 3 hours. Put 40% then 65% then 85% loads on it. All ran OK with no issues.
There is something that I noticed today but it came home this way. I do not think the motional transducer is operating properly. The starter pinion gear is not disengaging when the genset starts and reaches 900 rpm.
I tried to measure for dcv across the transducer. I think I recall reading that there should be about 3vdc or so. Still looking into it. Anyways there was no dcv across the terminals. When I removed it there was some junk on the magnet so I brushed that off and I am getting about 150 ohms across the transducer.
Any ideas on this one?
