mep804 what filters numbers do i need yamanar engine
97
9
SHENANDOAH PA
I drug home a mep804 generator yesterday. all fluids were drained and filters removed. I had a fleet guard fuel separator that spun right on from a 802-803 (I will post the fleet guard number later for future reference) . what I need is the secondary fuel and oil filter numbers for the civilian market. I don't care what brand, as long as I have one set of numbers I can always cross reference them. thanks in advance and have a nice holiday.
Guyfang
22,221
Burgkunstadt, Germany
Should you type in MEP-804B filters into the search function, you will find a thread that might answer some of your questions. 155MM started the thread. He has some 15 KW's and knows what the deal is.
Guyfang
22,221
OK, lets start over!
I just posted the YANMAR TM 9-2815-538-24&P in the TM upload forum. Have to admit, I never saw or worked on this engine. But I assume that if you look up the parts in the TM, and use the part numbers given, in your browser, they should cross over to civilian part numbers. Or try it with the NSN's.
9
SHENANDOAH PA
Ok i did the work, now i get to share the rewards.
Oil filter for yamanar diesel 4 cylinder
fram ph3593a
wix 51064 or 51334
napa 1064 or 1334 or 1338 or 1381
note napa filter just drops off the first number from wix filters. (a helpful thing to know)
fuel filter
fram p10796
mann wk7187
yamanar 11980255800
luber finer lff 8350
fuel seperator is the same as a 802,803,804
fleetguard fs1251
thanks many times to guyfang for all his help.
Dportm
Florida
fram ph3593a
wix 51064 or 51334
fuel filter
fram p10796
mann wk7187
yamanar 11980255800
fleetguard fs1251
Great info: Thanks for doing all the research
