MstrFiksIt
- 1
- 0
- Kalamazoo, MI
Back to the basics. Once i figured out the low voltage light was the relay but the generator would still shut down after about 30 to 60 seconds I also noticed that it was hard to start if you immediately reset and hit the start key. I did a little investigation and found one of the fuel hoses was collapsing and cutting off the supply. now the engine starts and stays running and with a few adjustments I am putting out the right amount of power. no if I can find a new relay for the over/under voltage everything will be back to normal. I want to thank you Guyfang for two things. your invaluable help with finding information and forcing me to look stuff up and find it more or less on my own. future problems with this thing will be much better solved with the knowledge you shared with me.
Gary
Gary
